LCD Seven Segment Displays
Discussion in 'General Electronics Chat' started by Overclocked2300, Jun 7, 2005.
  1. Overclocked2300
    Thread Starter Senior Member
    Apr 24, 2005
    124
    I was wonder..what is the difference between Reflective and Transreflective LCDs?
    Also Can I use LEDs to backlight a LCD 7 segment Display (such as the ones shown here: http://www.sourceresearch.com/shelly/image/7segmentLCD.jpg)
    If I could how would they be mounted? I see cell phones use this same Idea. I think they are mounted just below the LCD.
    EDIT: The circuit i want to build used LED 7 segment displays.. I dont want to use a LED display. The circuit uses a PIC. Would I have to reprogram the pic to fit the LCD?
    OR could I have the PIC output BCD and then convert it to LCD 7 segment code?
    http://translate.google.com/translate?hl=e...3D%26safe%3Doff
  2. lightingman
    Apr 19, 2007
    374
    22
    O.K.
    If you don't mind using an LCD, using a PIC is simple way to do it with just a few lines of code.
