lcd screen code problem
Discussion in 'Programmer's Corner' started by raw_653, Feb 9, 2012.
  1. raw_653
    Feb 3, 2012
    10
    hi all :)
    i wrote a code that is supposed to print the following on the screen
    cars number=0
    money=0
    but when i run it i get
    cars number=
    money= 0
    any solutions ?
    the code
    int i=0;
    int x=0;
    char itxt[16];
    char xtxt[16];
    void screen ()
    {inttostr(x,xtxt);
    inttostr(i,itxt);
    Lcd_out(1,1,"cars number=");
    Lcd_out_cp(itxt);
    Lcd_out(2,1,"Money=");
    Lcd_out_cp(xtxt);
  2. spinnaker
    Oct 29, 2009
    5,102
    1,190
    You are going to have to post your code for Lcdout_cp if you want someone to help. And use the code tags when posting code.
    Code ( (Unknown Language)):
    1.
    2. void screen ()
    3. {inttostr(x,xtxt);
    4. inttostr(i,itxt);
    5. Lcd_out(1,1,"cars number=");
    6. Lcd_out_cp(itxt);
    7. Lcd_out(2,1,"Money=");
    8. Lcd_out_cp(xtxt);
    9. }
    10.
  3. raw_653
    Feb 3, 2012
    10
    which code ?
  4. spinnaker
    Oct 29, 2009
    5,102
    1,190
    I think I already mentioned it.
    "You are going to have to post your code for Lcdout_cp if you want someone to help. And use the code tags when posting code."
  5. raw_653
    Feb 3, 2012
    10
    this is the code (on mikroc)
  6. spinnaker
    Oct 29, 2009
    5,102
    1,190
    What??????
  7. raw_653
    Feb 3, 2012
    10
    this the code that is responsible for the data output on the lcd screen
  8. spinnaker
    Oct 29, 2009
    5,102
    1,190
  9. raw_653
    Feb 3, 2012
    10
    the result when replacing the two calls
    cars number=1
    money=2
  10. spinnaker
    Oct 29, 2009
    5,102
    1,190
    Did you look closely at the link to the IntToStr documentation I posted? What differences did you see?
    If you did not look at it then why not? You need to put some effort into this too.
  11. raw_653
    Feb 3, 2012
    10
    i did and i couldn`t find any difference but nvm I am working on another code now
  12. spinnaker
    Oct 29, 2009
    5,102
    1,190
    Then you did not look close enough
    What is documented: IntToStr
    What you have : inttostr
    You don't see any differences?
