LCD Question
Discussion in 'General Electronics Chat' started by Dritech, Jun 1, 2012.
  1. Dritech
    Sep 21, 2011
    756
    5
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    The code is likely to be the same.
    Dritech likes this.
  3. Dritech
    Sep 21, 2011
    756
    5
    Thanks for your fast reply. So all i have to do is just plug it, right?
  4. nsaspook
    Aug 27, 2009
    3,011
    2,356
    It should work just fine but some of the clone controllers are slower than others (compared to a good HD44780 clone) so the delays might have to be tweaked if the setup and hold time were optimized to a faster chip.
    Dritech likes this.
  5. Dritech
    Sep 21, 2011
    756
    5
    ok thanks for your replies
  6. t06afre
    May 11, 2009
    5,939
    1,222
    I would think they function similar. But check the datasheet in case some of the pins has swapped place
  7. atferrari
    Jan 6, 2004
    2,663
    784
    Prior software, check if the hardware is compatible.
    1 - Check in your current module what pins are connected to backlight [anode / cathode], likely one of these combinations:
    15 A / 16 K (1 & 2 used for ???)
    1 A / 2 K (15 & 16 maybe used for DATA)
    Can you check that with a multimeter fitted with diode check function? That would be enough.
    2 - Check the datasheets offered and make sure which one matches your current layout.
    3 - Beware of "generics" where Optrex's (or whatever) is offered with the datasheet of Displaytech's (or whatever). I am afraid of this being the case. (204A-GC-BC-3LP / 204A-CC-BC-3LP?) Different results from a unique search...
    4 - If for any reason you go for other brands / models (old ones) prior all that check if pins in the PCB are numbered sequentially from 1 to 16 as in yours and not "16 15 1 2 3 4 5 6 ...". (This comes from when they added backlight capability to the initial 14 pins module designs).
    Be well.
