the LCD is damaged in dispaly, i tried to change it and replaced it with 16*2 LCD. It worked well, when I switched on AC supply the display vanished, again i need to reset the system, again same problem when AC supply switched on. Display is also going away when I am fixing nuts to the front panel..
Kindly suggest
Kindly suggest
