LCD Library
Discussion in 'General Electronics Chat' started by olvine, Apr 29, 2014.
  1. olvine
    Mar 10, 2014
    99
    whats the max frequency of MCU at which the mikroC lcd library work properly ??
  2. Brownout
    Jan 10, 2012
    2,375
    998
    None. You need to insure that the macros are properly defined for the frequency you are running, to make any delays work. I presently don't use the macros, but it's something like:
    #define FREQUENCY=fooMhz (not exact syntax, just look it up)
  3. olvine
    Mar 10, 2014
    99
    I am using PIC16F1827 and when using 32MHz clock frequency it gives random charactors on the lcd.
    And in simulation it gives expected results :/
  4. Brownout
    Jan 10, 2012
    2,375
    998
    Are you getting correct results at other clock frequencies? Are you setting the macro? 32 MHZ isn't a problem as long as you set things up correctly.
