Hi Guys,
I am trying to build my first robot. The thread with more information on it is actually on a different board here.
With the help of this thread, I came up with this diagram:
(Also attached)
I found that when I have the LCD backlight on, the display flickers a lot when I have the IR sensor connected as well.
Can someone tell me if the voltage regulator would help with the flickering? Or is it overkill and should I rather just use bypass caps?
Hope someone can point me in the right direction.
(Also attached)
