lcd interfacing with 8051 c programming
Discussion in 'Embedded Systems and Microcontrollers' started by khan yousufzai, Sep 1, 2012.
  1. khan yousufzai
    Aug 31, 2012
    please anybody send me lcd all commands c programming 8051 microcontroller i use,,,,please also tell me that commands for 16x2 lcd and 16x4 lcd are the same or different
  2. madhusuthanan
    May 30, 2012
    hi khan yousufzai,
    The commands are same for 16x2 &16x4 but the address are different. the commands are get from google itself.
  3. mukesh.sehwag
    Oct 16, 2010
    1. 0X38 - Initialization of LCD
    2. 0X0E - Cursor on of LCD means it will show the cursor
    3. 0X01 - It will clear the LCD screen (if already some data has been written)
    4. 0X06 - It will start writing the data from left to right
    0X04 - It will start writing the data from right to left
    Send any one of the two(06 or 04) command to LCD
    5. 0X80 - It will Start the cursor from first row and first column. Change it according to your requirement from 80 to 8F.
    0XC0 - It will start the cursor from second row first column. Change it from C0 to CF (for 16*2)
    For 16*4 only the 5th command will differ.
  4. t06afre
    May 11, 2009
    Also the correct timing is VERY important. If you write a command to the LCD before it is done with the previous. The LCD will not work properly. The datasheet will inform you about the details regarding this matter
