LCD header pins soldering
Discussion in 'General Electronics Chat' started by edwards.aus, Jul 23, 2010.
  1. edwards.aus
    Jul 23, 2010
    Hi all,
    I have a HD44780 standard LCD which comprises of a LCD display panel on a PCB (that contains the 16 pin holes for soldering in the 16-pin headers).
    Can I can solder the 16-pin header into those holes without removing the LCD display panel? Just want to make sure that I do not damage the LCD panel due to heat. :)
    Thanks,
    Edwards
  2. retched
    Dec 5, 2009
    5,201
    313
    Yes, I do it often.
    Just be careful and watch your solder times.
    If you take more than a few seconds on a pin, you may want to wait a few seconds before moving on to the next pin.
    I have never had a problem with solder times affecting my LCD.
