Hi
I recently bought a very cheap bit of chinese electronic junk and the first thing that happened was that one of the plugs fell inside the box so I had to get the the screwdriver out within minutes of getting it.
This thing has a processor of some kind and an LCD display. What I found was the circuit board (with the processor) is not attached to the display by the usual sort of ribbon cable or edge connector but this wierd sort of foam rubber sandwich affair which seems to rely on being squished between a line of contacts on the circuit board and the display itself.
If you hold the display up to the light there seems to be a 'matching' set of very faint contact lines on the edge (where the other side of the foam rubber sits) which I assume is some sort of conductive layer.
I'm assuming this 'foam rubber' thingy also contains some sort of conductive material, but how the whole thing keeps in line god only knows which is probably why the display is pretty flaky at the best of times (and if you dont get the right amount of squish and alignment it won't work at all)
Any pointers or any info on what this thing is and how it works gratefully received !
Thanks, Si
Thanks, Si
