LCD display backlight voltage
Discussion in 'The Projects Forum' started by eminthepooh, Nov 8, 2012.
  1. eminthepooh
    Aug 26, 2012
    27
    Hello, I'm designing a system to be mass produced which has this charecter LCD (common HD44780 controller). As stated in some datasheets the LCD backlight voltage drop is minimum 4.2V maximum 4.8V. I'm controlling its operation with a mosfet and resistor as seen in the picture.
    I'm wondering if there is an easy/rule of thumb way to design without a pot (currently using pot set at ~4ohms) so that my circuit with work every time regardless of the backlight voltage drop. I've considered going to a 12V power supply to have a greater range in control. Any suggestions?
    Thank you,
  2. ScottWang
    Aug 23, 2012
    4,925
    777
    The better way is fixed the voltage of backlight of LCD.
    If you need to adjust the voltage of backlight, you could use the DIP Switch to choose the resistors you want, the DIP Switches has many kinds of pins, as 2,4,6,8,10,12 pins, DIP Switch.
  3. tubeguy
    Nov 3, 2012
    1,157
    197
    Could you post a link to a datasheet for this device?
