Hi everybody,
I was trying to write a simple LCD testing program to display "P" on 1st line and display "L" on the 2nd line, but my 16x2 LCD just show 2 line of grey square. I was using the Port C & Port D of my PIC16F877A and using 8-bits interface to display character on my LCD. I also try to put a pullup resistor to all the port's pins that used but the results is still the same. The 8 data pins of the LCD is connect to Port D and RS, RW, E is connect to the first 3 pins(RA0, RA1, RA2) of Port C.
I was using CCS C compiler, to write this testing program i was refer to the information provided in the HD44780U datasheet.
Anybody can give some suggestions regarding the error that i have make?
The testing program is shown below.
Any suggestion will be greatly appreciate.
Thanks.
Thanks.
Rich (BB code):
#include <16F877A.h>
#fuses hs, nowdt, nolvp, noprotect //Config
#use delay (clock = 20000000) //20MHz Crystal
void init(void); //Function Prototype
void busy_test(void);
void display(void);
void send_command(void);
void send_data(void);
unsigned char PORTC, TRISC, PORTD, TRISD, RS, RW, E, BF;
unsigned char command, data;
#byte PORTC = 0x07
#byte TRISC = 0x87
#byte PORTD = 0x08
#byte TRISD = 0x88
#bit RS = PORTC.0
#bit RW = PORTC.1
#bit E = PORTC.2
#bit BF = PORTD.7
void main()
init();
display();
while (1)
void init()
PORTC = 0x00; //Clear Port C
PORTD = 0x00; //Clear Port D
TRISC = 0x00; //Set Port C As Output
TRISD = 0x00; //Set Port D As Output
delay_ms (500); //Power-On Delay
//Busy Flag Valid Here
//busy_test(); //Check Busy Flag
command = 0x38; //8-Bits, 2-Lines, 5x7 Dots
send_command(); //Send Command To LCD
delay_ms (10);
delay_us (500);
delay_ms (1);
delay_ms (1);
busy_test(); //Check BF
command = 0x08; //Display Off, Cursor Off, No-Blink
delay_ms (1);
busy_test();
command = 0x01; //Clear Display
send_command();
delay_ms (5);
busy_test();
command = 0x06; //Increment Cursor Position, No-Shift
send_command();
delay_ms (1);
busy_test();
command = 0x0F; //Display On, Cursor On, Blink
send_command();
delay_ms (1);
void display()
busy_test();
command = 0x80; //Set DDRAM Address To 0x00
send_command();
delay_ms (1);
busy_test();
data = 0x50; //Display "P"
send_data();
delay_ms (1);
busy_test();
command = 0xC0; //Set DDRAM Address To 0x40
send_command();
delay_ms (1);
busy_test();
data = 0x4C; //Display "L"
send_data();
delay_ms (1);
void busy_test()
while (1)
TRISD = 0xFF; //Set Port D As Input
//RS = 0; //Command
//RW = 1; //Read Busy Flag
PORTC = 0x02;
delay_cycles (2); //Control Setup Time
//E = 1; //E-Line High
PORTC = 0x06;
delay_cycles (6); //Wait Data Return
if (BF == 0)
TRISD = 0x00; //Set Port D Back To Output
//E = 0; //E-Line Low
PORTC = 0x02;
return;
PORTC = 0x02;
} //End while loop
} //End Function
void send_command()
//RS = 0; //Command
//RW = 0; //Write Instruction
PORTC = 0x00;
PORTC = 0x04;
delay_cycles (3);
PORTD = command; //Put Command To Port D
delay_cycles (3); //Data Setup Time
PORTC = 0x00;
delay_cycles (1); //Control & Data Hold Time
void send_data()
//RS = 1; //Data
//RW = 0; //Write data
PORTC = 0x01;
PORTC = 0x05;
delay_cycles (3);
PORTD = data; //Put Data To Port D
PORTC = 0x01;
