Hi guys,
I wish someone could give me an advice with the following:
I wanted to replace a 240x64 LCD module, model PG24064-E (EL backlight) and ordered an LED backlight one, model ERM24064FS-1. Only upon arrival I have realised that it's a 22 pin version and the previous one is a 20 pin version. I have checked the data sheets and pins 1-20 are the same on both units and the last two pins on the new one are for powering the LED backlight. Now how could I use this with a 20 pin connector? Can I just solder in a 20 pin header and solder a piece of wire between the module power supply the LED power supply + to + and GND to GND? They both take 5V DC..
I know this might be a very silly question, but I don't actually know much about electronics, I just want to replace the LCD in my device. Your help is much appreciated guys! Cheers!
