lcd 4bit mode asm custom character
Discussion in 'Programmer's Corner' started by hby01, Apr 15, 2014.
  1. hby01
    Mar 20, 2014
    Hi guys. I'm relatively new to mplab and i am working on a project using assembly language which at some point requires me to display a custom charactor that i created on the 16x2 lcd in 4 bit mode exclusively. Now i know that i need to first set the cg ram address and then load the combination of bits to the cg ram but I cant figure out a way to do so. And i tried searching the web for any refernces but all were written in c. So please guys i really someone to give me an example or a sample code where we display a custom character after creating it on lcd.
  2. ScottWang
    Aug 23, 2012
    4,925
    777
    Google : interfacing lcd 4bits asm
    using google to search then you will get a lots of samples, change the keyword then it will show up different infos.
    PIC Projects -- Driving LCD 4-bit mode.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    What do you struggle with regarding LCDs and 4 bit mode? Let us start in that end of the problem
  4. shteii01
    Feb 19, 2010
    3,500
    511
    LCD datasheet tells what needs to be done to load custom character. It may or many not have step by step instructions.
  5. ErnieM
    Apr 24, 2011
    7,435
    1,625
    I would suggest learing to read code written in C.
    Reading code is far easier then writing it, and you get all the steps you need to accomplish your task.
  6. t06afre
    May 11, 2009
    5,939
    1,222
    So true, but it still will help much. If your teacher say you must write the program in assembler:rolleyes:
  7. THE_RB
    Feb 11, 2008
    5,435
    1,305
    THe C code examples will tell you what you need to do. You send a command to set CG ram, you send the 8 bytes to load the character into CG ram. Then display is the same as any other characters, user CG ram are 8 locations addressed 0-7.
