1. I have interfaced 16x2 lcd in 4 bit mode. D0-D3 & R/w of lcd are grounded.
2. If system is power on, then lcd works properly. No issue. I have tried many times.
3. But when I press reset button on MCU so that it get reset & reinit the lcd. It don't works most of the time.
I don't understand why. Sometimes some random chinese number, some cursor only & sometimes random numbers.
4. All other pins interfaced worked fine when MCU get reset like led's & adc module except lcd.
5. Below is my code for lcd.
Code:
void main(void)
const uint8_t str1[] = "******";
const uint8_t str2[] = "999999";
configure_lcd();
lcd_string_print(&str1[0] , 0x80U);
lcd_string_print(&str2[0] , 0xc0U);
while(1);
void configure_lcd(void)
initialize_lcd_pins();
init_lcd();
void lcd_string_print(const uint8_t *p_str , uint8_t address)
uint8_t cnt = 0U; /* max 16 chars to be printed */
write_lcd_command(address);
while( (*p_str != '\0') && (cnt < 16U) )
write_lcd_data(*p_str);
p_str++;
void write_lcd_data(uint8_t value)
uint8_t cnt;
LCD_RS_HIGH();
shift_data_on_lcd_pins(value & 0xf0U);
toggle_lcd_en_pin();
/* delay for 12ms */
__delay_us(12000);
shift_data_on_lcd_pins( (value << 4U) & 0xf0U );
toggle_lcd_en_pin( );
__delay_us(12000);
void write_lcd_command(uint8_t value)
uint8_t cnt;
LCD_RS_LOW();
__delay_us(12000);
__delay_us(12000);
static void init_lcd(void)
uint8_t cnt;
/* delay for 300ms */
__delay_ms(300);
/* rs shoud be low */
LCD_RS_LOW();
/* write 0x30 on port */
shift_data_on_lcd_pins(0x30U);
__delay_us(12000);
__delay_us(12000);
__delay_us(12000);
/* write 0x20 on port */
shift_data_on_lcd_pins(0x20U);
write_lcd_command(0x28U);
__delay_us(12000);
write_lcd_command(0x0cU);
__delay_us(12000);
write_lcd_command(0x01U);
__delay_us(12000);
write_lcd_command(0x06U);
__delay_us(12000);
write_lcd_command(0x80U);
__delay_us(12000);
write_lcd_command(0x0eU);
__delay_us(12000);
static void shift_data_on_lcd_pins(uint8_t value)
if(value & REG8_BIT_7)
LCD_D7_HIGH();
else
LCD_D7_LOW();
if(value & REG8_BIT_6)
LCD_D6_HIGH();
else
LCD_D6_LOW();
if(value & REG8_BIT_5)
LCD_D5_HIGH();
else
LCD_D5_LOW();
if(value & REG8_BIT_4)
LCD_D4_HIGH();
else
LCD_D4_LOW();
void initialize_lcd_pins(void)
LCD_EN_OUTPUT_LOW();
LCD_RS_OUTPUT_LOW();
LCD_D7_OUTPUT_LOW();
LCD_D6_OUTPUT_LOW();
LCD_D5_OUTPUT_LOW();
LCD_D4_OUTPUT_LOW();
static void toggle_lcd_en_pin(void)
LCD_EN_HIGH();
__delay_us(500);
LCD_EN_LOW();
__delay_us(500);
