lcc resonance converter
Discussion in 'General Electronics Chat' started by karas, Aug 6, 2016.
  1. karas
    Thread Starter Active Member
    Sep 8, 2011
    127
    I am try to do simulation for LCC converter ,the wave form on R4 should be high frequency(100khz) with envelop of sine wave,but i can not get it with simulation so what i miss , and also this circuit has output of 24vdc and io=5A so can someone help me with the simulation of this circuit
    • LCC.asc
      File size:
      3.3 KB
  2. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Your V1 settings are way off. Try setting V1 as PULSE(0 5 0 10n 10n 5u 10u).
  3. karas
    Sep 8, 2011
    127
    Thanks so much,i did try and at the off time is not going to zero and is ringing
  4. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Not surprising, with C4,L3,C3,L1 present.
  5. karas
    Sep 8, 2011
    127
    do you have an idea how can i get 24vdc and io=5A
  6. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Not with a 90-264V AC input range.
    Edit: Google 'fly-buck converter' to see the general approach.
  7. karas
    Sep 8, 2011
    127
    can you do it with 120+-10%
  8. Alec_t
    Sep 17, 2013
    5,971
    1,135
    I'm sure someone can, but not me. The tricky part would be designing and making, or acquiring, the right transformer. Magnetics aren't my forte. I'd just buy an off-the-shelf converter, which would be cheaper than the cost of its parts to me.
