LC Circuit Input Admittance
Discussion in 'Homework Help' started by jegues, Feb 6, 2012.
  1. jegues
    Sep 13, 2010
    735
    43
    I'm confused as to how I'm supposed to solve for an LC circuit having the following admittance in the s domain,
    Y_{in}(s) = \frac{0.5s}{s^{2}+1} + \frac{2s}{s^{2}+2}
    Can anyone explain how?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Consider a series LC branch which has an impedance
    Z(s)=Ls+\frac{1}{Cs}=\frac{L(s^2+\frac{1}{LC})}{s}
    The admittance of such a branch is
    Y(s)=\frac{s}{L(s^2+\frac{1}{LC})}
    Now consider two such series LC branches with different L,C values connected in parallel.
    Remember: parallel branch admittances are additive
  3. jegues
    Sep 13, 2010
    735
    43
    So I can start the design with 2 different C values and 2 different L values, (i.e. two L and C series branches in parallel with one another) which I can then reduce to one L and one C?
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    The resulting 4 element network may be reducible but presumably not to a simple series LC equivalent.
