Lbview interfacing with USB1208 HARDWARE
Discussion in 'The Projects Forum' started by irfan16, Apr 2, 2012.
  1. irfan16
    Dec 29, 2011
    12
    Dear All
    I am using labview 8.2 and want t o interface sensor with 0~5dcout put to labview through the hradware USB1208 (MEASUREMENT COMPUTING)..Can anyone guide me how I configure USB1208 Hardware with Labview..
    Kind Regards
    Muhammad Irfan
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    This is not a physics problem, so I moved it.
  3. t06afre
    May 11, 2009
    5,939
    1,222
  4. Stuntman
    Mar 28, 2011
    189
    50
    There are often many ways to do the same thing.
    8.2 is about the last version I did some hardware automation with. I found for some older hardware, it was easier to write control scripts from strings then put over (in this case) GPIB as opposed to use the downloaded control Sub VI's.
    However, it looks like from the link t06afre provided, you can use their software to generate these sub VI's, then include them in your code? If so, that would be gravy.
