Layers in Eagle PCB design
Discussion in 'Electronics Resources' started by matrixofdynamism, Dec 12, 2010.
  1. matrixofdynamism
    Feb 8, 2009
    11
    Can you tell me as to why there are so many layers in Eagle PCB program??
    Also what type of wire thickness should we use and when?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. tyblu
    Member
    Nov 29, 2010
    199
    16
    You're likely using the free EAGLE version, which I believe has even less layers than what you would normally start with. Each layer contains a different type of information -- types you don't want to interfere with eachother. Also, the PCBs themselves can be multiple layers of conductors and insulators. You can also add custom layers for PCB fab notes, etc..
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    As a simple example of how to use the layers, consider that you have a nice, fully routed board design. Go to views and select "unrouted" only. Then you can see if you missed anything. The erase command only works on the layer that is shown, so you can use that to your advantage. The origin layer is something you may want to leave "not shown," so you don't move something accidentally while routing. Etc.
    John
