Lathe Problem
Discussion in 'General Electronics Chat' started by Sargent2095, Dec 1, 2015.
  1. Sargent2095
    Dec 1, 2015
    I have a Jet GHB 1340 A lathe that won't run. The motor will run if I push the contactor in,(and it will hold), but it acts as if it is not getting any power otherwise. The digital read out works fine and the lathe is getting power from the buss head. Any suggestions?
  2. DNA Robotics
    Member
    Jun 13, 2014
    135
    33
    Check the On / Start switch and its circuit to see if it is sending power to engage the contactor. Fuses?
  3. gerty
    Aug 30, 2007
    1,154
    304
    +1 Start switch..
  4. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    Does the contactor have an overload block that needs resetting on the output side?
    Max.
