latest op-amp
Discussion in 'Homework Help' started by swty_todd, Feb 24, 2009.
  1. swty_todd
    Thread Starter Active Member
    Aug 3, 2008
    82
    v hav 2 make project which involves comparing op-amp 741 and any one of the latest op-amps..cn anyone suggest the any latest op-amp??
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    There are so many to chose from. The LM6171 is 100 MHz, very high slew rate, and is discussed in this article (Working with Cranky Op-Amps), so you would have something to say about it as well. Some other high frequency choices are LMH6550 and LMH6609.
    It would be easier to advise, if you gave some criteria, like low offset, nulling pin, unity-gain bandwidth, slew rate, supply requirements, that you want to examine and compare.
    John
  3. mik3
    Feb 4, 2008
    4,846
    63
  4. swty_todd
    Aug 3, 2008
    82
    actually more the parameters the better..bt i shld understand them 2 n v hav jst strted with op-amps..v hav studied parameters like input offset voltage, input offset current,input bias current ,CMRR,transient response,slew rate,gain-bandwidth product, temperature coefficients etc..
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    All op-amps come the the same number of "parameters." That number depends on how extensively you want to characterize the component. The question is, which characteristics are of interest to you.
    Please translate to English.
    John
  6. swty_todd
    Aug 3, 2008
    82
    But i should understand them and we have just started them
