Latching switch for AC
kiranr
Joined May 1, 2009
25
I'm looking for a latching switch which can be triggered by 5V DC and which can switch 230v AC.
My basic need is that the device will turn on one pulse and will remain on until an off pulse is given.
I looked into triacs but could not exactly figure out how to achieve the latching. I'm planning to drive household appliances like light and fan.
I originally thought of latching relays but couldn't find one in ernakulam. Which would be better for home automation?
Could someone point me in the right direction.
SgtWookie
Joined Jul 17, 2007
22,230
If the 230v being switched is L1 and L2 (two "hot" leads) then both must be switched; otherwise the appliance or device will still be connected to the mains when just L1 or L2 are interrupted.
If there is just L1 (hot) and Neutral, then you can simply switch L1.
zgozvrm
Joined Oct 24, 2009
115
Good point. I replied a bit too quickly. Should probably actually use a 3PDT relay (or only 3 of the 4 contacts of a 4PDT relay).
kiranr
Joined May 1, 2009
25
Latching relays were my first considerations. (I'm using single phase.) But with relays there is the switching sound and as this is for appliance control at home, i was trying to get rid of the noise and improve durability. Plus, I wanted to learn about solid state switching.
Of course, if not viable i understand that relays are the way to go.
Thank you for your replies.
You can use high voltage MOSFETs. They are easier to control than a TRIAC; however, you will need to use two in series because you are switching an AC signal, and a MOSFET has an intrinsic (built-in) diode that will conduct for one half of the AC cycle.
You can design a circuit similar to Kermit's where the output powers the gates of the FETs, or latching can be built from some digital logic, if you have the space for ICs.
zgozvrm
Joined Oct 24, 2009
115
You might look into opto-isolated output modules. I use input and output modules from Opto-22 (see http://www.opto22.com/). The also have solid state output modules for higher power switching.
As for latching, you would do that in the control logic.
