Latching relay with 2 coils protection.
www111
Joined Apr 19, 2013
Hi all,
I bought a Latching relay RT314F05 and my question is how to set the protection diodes for coil?
Schematic is attached:shematic
Will those transistors work: Nmos
What kind of diodes should I use?
Any suggestion well appreciated.
Best Regards.
Alec_t
Joined Sep 17, 2013
14,335
I don't follow your schematic. If the relay is a twin coil type why are you driving both coils in parallel? Shouldn't one coil be used to set the relay and the other coil be used to reset it?
Edit:
According to the datasheet A3 goes to +V, A2 is switched to -V to set the relay, A1 is switched to -V to reset it.
Like this
Alec_t
Joined Sep 17, 2013
14,335
As for whether the FET linked to is suitable, that depends on the gate drive voltage and the relay coil voltage and current. The datasheet shows various coil voltages according to model.
