Latching a logic signal
Discussion in 'General Electronics Chat' started by Dritech, May 17, 2014.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    I am using a current sensor to switch off a relay when a particular motor exceeds its current limit. I want the relay to remain off until a reset button is pressed. What type of latching IC or circuit can I use to achieve this please? Ideally it have to be a simple circuit or a single IC.
    Thanks in advance.
  2. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    If the current sensor is N.C. then place a N.O. contact on the sensing relay in series with its coil, place a reset or arming N.O. P.B. in parallel with the N.O. contact.
    The current sensor will have to have returned to its N.C. state to enable a reset.
    Max.
  3. ErnieM
    Apr 24, 2011
    7,434
    1,625
    The simplest part is the one you already have: the relay itself. Put a normally open relay contact in series with the relay coil. When the current sensor breaks the circuit this contact will keep it off until the reset button is pressed.
  4. crutschow
    Mar 14, 2008
    13,469
    3,356
    Here's one way to do ErnieM's suggested circuit. The reset switch won't energize the relay unless the current limit switch is closed (indicating no overcurrent).
  5. ronv
    Nov 12, 2008
    3,392
    1,448
    Or if you want logic.
    Dritech likes this.
  6. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    Also post #2;)
    Max.
  7. profbuxton
    Member
    Feb 21, 2014
    233
    68
    Simple method: Use a magnetically latched relay. These have two coils operating the same contact set. One coil "sets" the relay and the other coil "resets" the relay. Use your Current sensing to "reset" the relay to off and a pushbutton to "set" the relay to on.
  8. crutschow
    Mar 14, 2008
    13,469
    3,356
    Sorry Max, didn't mean to slight you. :p
  9. Dritech
    Sep 21, 2011
    756
    5
    Thanks for the replies :)
  10. strantor
    Oct 3, 2010
    4,302
    1,989
    you're welcome
