latch circuit
Discussion in 'General Electronics Chat' started by fred_uk, Feb 11, 2009.
  1. fred_uk
    Thread Starter Active Member
    Jan 3, 2009
    67
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It's one method of making a latching circuit. What are you latching? Why are you latching it?
  3. fred_uk
    Jan 3, 2009
    67
    it goes to a digital input on a gsm modem that needs to be held high until it is reset using the reset input. battery consumption is also an important factor. i like the circuit listed because it has a reset and alarm led, i would like to use a bi coloured led, flashing say once every 30 seconds green if reset and red every 30 seconds of in 'alarm' condition.
    thanks
    fred
  4. mik3
    Feb 4, 2008
    4,846
    63
    Use a RS latch IC of the CMOS technology to reduce power consumption. CMOS consume less power when used in low frequency applications compared to TTL.
  5. fred_uk
    Jan 3, 2009
    67
    would the same ciruit be suitable with a different ic?
  6. mik3
    Feb 4, 2008
    4,846
    63
    Yes, if the ic has the same function.
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  8. fred_uk
    Jan 3, 2009
    67
    is that like a potential divider... bit new to this...sorry!
  9. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Normal TTL (74XX) and HCT (74HCTXX) will work from 4.75 to 5.25 Volts.
    Cmos (40XX) will work from 3 to 15 Volts.
    HC mos (74HCXX or 40HCXX) will work from 3 to 6 Volts.
    Greetings,
    Bertus
  10. fred_uk
    Jan 3, 2009
    67
    looks like i need to contact the manufactures and confirm what the inputs are and their ratings!
  11. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
