Laser Rust Remover
Discussion in 'The Projects Forum' started by LordLion, Apr 14, 2016.
  1. LordLion
    Mar 31, 2016
  2. #12
    Nov 30, 2010
    16,655
    7,293
    Can you find a 1000 watt laser diode?
    I don't think so.
    Maybe Spectra Physics will sell you a 1000 watt laser if you prove you can use it safely.
    No. They only go to 200 watts.
    How many thousand dollars do you have for this project?
    LordLion likes this.
  3. LordLion
    Mar 31, 2016
    means we can't built it at home in less money
  4. wayneh
    Sep 9, 2010
    12,362
    3,220
    No, we can't. This would be an extraordinarily bad do-it-yourself project. It would be very dangerous, and probably impossible to get the supplies anyway. Stick to steel wool and Coca Cola.
  5. shortbus
    Sep 30, 2009
    4,082
    1,663
    Old school. The latest and greatest is this stuff - http://www.evapo-rust.com/
  6. SLK001
    Nov 29, 2011
    848
    241
    There is also the electrolysis method using water, current and sodium carbonate (washing soda).
    LordLion and shortbus like this.
  7. wayneh
    Sep 9, 2010
    12,362
    3,220
    Have you tried it? My go-to used to be Naval Jelly but I'll try this stuff if it's better.
  8. #12
    Nov 30, 2010
    16,655
    7,293
    I still have half a gallon of, "Os-fo" phosphoric acid.
    Strange, the results look just like the results of Evapo-rust.
  9. wayneh
    Sep 9, 2010
    12,362
    3,220
    The MSDS claims it contains a proprietary detergent and a proprietary chelating agent. That could be a fancy word for phosphoric acid, but they would be risking a lot by shipping phosphoric acid without noting so on the MSDS.
  10. shortbus
    Sep 30, 2009
    4,082
    1,663
    Ospho used to be used as a metal conditioner. Put it on bare metal before primer. Never tried it for removing rust. It is kind of like a easy version of Parkerizing, no hot tanks needed.
  11. shortbus
    Sep 30, 2009
    4,082
    1,663
    Not personally, but professional metal shapers on another forum have good things to say about it
  12. shortbus
    Sep 30, 2009
    4,082
    1,663
    That's kind of a slow process. Another trick if you have time to do it, is a container of molasses. Not the cooking type but the raw stuff from a feed store.
  13. SLK001
    Nov 29, 2011
    848
    241
    It is slow, but it can actually reverse the rusting. Usually a soak overnight in an electrolysis solution will be enough. Just be sure to connect the electrodes in the correct polarity. One way reverses the rusting - the other way accellerates the rusting.
  14. atferrari
    Jan 6, 2004
    2,663
    783
    Wonder how big the pieces could be and how long it could take vis-a-vis the surface to treat. What about irregular shapes?
    Looks like the liquid we used on board (sure you have big surfaces there); rust converter serving as a base for the primer. I cannot remember the brand and could not find it either in the Hempel's catalog.
  15. shortbus
    Sep 30, 2009
    4,082
    1,663
    There are also, "rust converters", that change ferric oxide(rust) into another ferric compound. These converters don't remove the rust but change it into another form. Most use tannic acid instead of phosphoric acid.
