laser hair removal device
Discussion in 'The Projects Forum' started by kobebe, May 6, 2016.
  1. kobebe
    May 6, 2016
    9
    I wonder if someone here ever consider how to build one.
    there is a video on youtube that shows how to build a laser tattoo removal device.
    i want to build laser hair removal device, powerful enough to kill the hair root.
    could someone of you may help me with that project?
  2. GopherT
    Nov 23, 2012
    6,309
    4,029
    If you want someone to build the design the project, explain how it works, and give you step-by-step instructions to build the project, then no. That is not what this site does. If you have some questions as you research and develop your idea/product, or have questions when you open up and analyze how existing products work, or a detailed question of what is the best way to X, y or z. Then, we can help you with that.
  3. wayneh
    Sep 9, 2010
    12,382
    3,239
    The circuit part of this project is relatively simple. But personally, without more research, I have no idea what wavelength you want to use, what intensity to use, whether to pulse it, what safety features to build in, and so on. Frankly I'd be afraid to work on something that is powerful enough to kill hair follicles, because that means it is almost certainly powerful enough to also burn my retina. But maybe they build in a surface detector, so the laser shuts off if it doesn't see a reflection from nearby skin.
    If you can come back with some of that research, building a laser driver is "trivial".
  4. mcgyvr
    Oct 15, 2009
    4,789
    975
    JohnInTX likes this.
  5. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    @kobebe Please post a question ONLY to one thread.
  6. kobebe
    May 6, 2016
    9
    o.k sorry for that. wont be doing it anymore i was not sure wher to post the question (i'm new here)
  7. kobebe
    May 6, 2016
    9
    Thanks for your quick respond
    I want to use 808nm and i want to be able to play with the intensity it's should be adjustable between 15-35 joules - 20-35ms (pulsed). the safety that i want is key switch and press button.
  8. kobebe
    May 6, 2016
    9
    I love Social Justice and I'm fighting for it in many aspects.
    The laser hair removal industry are taking lots of money for those treatment- about 2000$ and more/
    there are many home laser devices like the Tria laser, Trialma, No No Hair..etc' and they are not powerful enough like those that the clinic are using, although they can make them powerful enough.
    There are not even one video on the web that shows hot to build one and how to hack one of those home devices ( I wonder why ).
    almost every one of us people love the feeling of smooth skin men's and women's.
    If we build home laser hair device that will actually work we can save a lot of money for us and for our families.
    I really hope you help me with that
    I want to use 808nm and i want to be able to play with the intensity, it should be adjustable between 15-35 joules - 20-35ms (pulsed). the safety that i want is key switch and press button.
    There is video in youtube- " Tattoo laser Hair Removal " It is very close to what i want to build
    I'm hoping you help me with the project
  9. Alec_t
    Sep 17, 2013
    5,971
    1,135
    I share Wayneh's doubts (post #3) about the safety aspect of this project, especially if you "want to be able to play with the intensity". Even stray IR reflected from something can be dangerous to your (or someone else's) eyesight. Excessive intensity could also cause permanent skin damage/scarring. There is good reason why instructions and advice on how to build the device yourself are scarce :eek:.
  10. kobebe
    May 6, 2016
    9
    o.k one more safety that i need it to have is that it start only when it touches the skin surface.
  11. kobebe
    May 6, 2016
    9
  12. joeyd999
    Jun 6, 2011
    2,756
    2,925
    Ultimately, I think you'll have to raise your price to cover the cost of litigation due to the 2nd and 3rd degree burns your product is going to cause...
    Edit: and deaths from misuse of topical anesthetic.
  13. wayneh
    Sep 9, 2010
    12,382
    3,239
    A quick search for the relevant regulations gives a pretty good idea of why this project is DOA.
    And by the way, the term "justice" requires no qualifier such as "social". There is either justice or there is not. The use of a qualifying term shows that what is desired not Justice at all, but something else closer to one political position winning over another.
  14. joeyd999
    Jun 6, 2011
    2,756
    2,925
    Specifically, "Social Justice" == "Things for Free" | "Personal Responsibility Not Required".
  15. kobebe
    May 6, 2016
    9
    I never said i want it for free, the amount of money those clinics are taking is huge! I think it worth no more than 500$ for full body which i'm willing to pay but it's not enough for them. if you want to help then help if not, please don't post. this is not the police/ or some kind of medical government site
  16. kobebe
    May 6, 2016
    9
    I know how to use those devices because i have done it in the past. the risk is on me
  17. hp1729
    Nov 23, 2015
    2,097
    232
    So that's like15 to 35 Watts for an IR emitter?
  18. joeyd999
    Jun 6, 2011
    2,756
    2,925
    "Shut up!" said the SJW. Typical.
  19. Alec_t
    Sep 17, 2013
    5,971
    1,135
    35 Joules = 35 Watt seconds. That much energy in a 35mS pulse equates to a 1000W source! :eek:. You could cut sheet steel with that!
  20. bertz
    Member
    Nov 11, 2013
    239
    31
    The price that the hair removal clinics charge is quite likely the correct price. It is the intersection of where the supply and demand curves intersect and Oh by the way they are entitled to a profit. Obviously there are enough individuals who are willing to pay the price the clinics charge or they wouldn't be in business. If you can afford it fine. If you can't afford it then too bad. Hair removal is not a necessity like food, clothing or shelter. The next thing you'll be asking for is free cell phones - oh wait, they already have them.
    By the way are you aware that a 35 watt laser diode costs around $1000. I shudder to think what a device like that can do in the hands of an amateur, like handing a loaded gun to a 6 year old. Not to mention the fact that you want to use it on other human beings.
