Laser emitter+receiver: how to
Discussion in 'General Electronics Chat' started by xnihilo, Dec 15, 2008.
  1. xnihilo
    Thread Starter Active Member
    Nov 20, 2008
    33
    I would need to substitute an IR data transfer system (IR led and IR receiver-demodulator at 40KHz) with a laser transfer because using an IR led and a lens is not accurate, the beam spreads as range increases.
    I'm working on a lasergame equipment and I would need accuracy.
    I have absolutely no idea of what I should use as a receiver for the laser beam, should I use a photodiode/phototransistor? Is there some information available somewhere? Looking in Google didn't bring me any good results.
    Any clue would by welcome.
    Thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Does this mean you are trying to direct an IR beam to specifically illuminate one sensor but not be detected by another a few cm away? At what distance?
