Laser diode help
Discussion in 'General Electronics Chat' started by Peter basolo, Dec 27, 2014.
  1. Peter basolo
    Nov 24, 2014
    38
    So I built my own laser reset me with double a batteries as those were my most accessible source of power and though I have the optimal current/voltage it only seems to be about 1/10 of what the diode is rated for (it's rated for 150 mW). The driver board and I am usingas has a potentiometer but once I get it to its brightest and turn it a little farther it just shuts off which is strange but I'm just assuming that's how this particular board work it's made by aixizI know it's a good board but I cannot see the being nor does any electrical tape burden or match light so therefore leave meet you to think that Waze or a burning around 15 mill lots and 30 mW which is obviously a lot less than I bought the diode for so was wondering if you had any input as to what I should do or if buying a lithium polymer battery would be my only option. The diodes Automall current/voltage is i'll hundred and 120 mA/6 V. The diode can run safely at 160 mA but dies out around 180 the seller said. So thanks for reading this horribly long posts and I appreciate your input. :)
  2. shteii01
    Feb 19, 2010
    3,518
    515
    Links to datasheets.
    Peter basolo likes this.
  3. Peter basolo
    Nov 24, 2014
    38
    There isn't anything here?
  4. ian field
    Distinguished Member
    Oct 27, 2012
    4,460
    792
    A laser diode should be powered by constant current - if you've fed it from a potentiometer and cranked it up till it goes off again; its probably toast!
    150mW isn't trivial for a set of AA cells - you might have dodged the bullet if the terminal voltage collapsed because of the cells internal resistance.
  5. Peter basolo
    Nov 24, 2014
    38
    What would you recommend for a portable power supply?
  6. ian field
    Oct 27, 2012
    4,460
    792
    What voltage headroom available?
  7. Peter basolo
    Nov 24, 2014
    38
    I contacted the seller of the diet Road in though the optimal voltage is six he suggested a 9 V battery.
  8. ian field
    Oct 27, 2012
    4,460
    792
    Most 9V batteries are layer type with very low energy density.
  9. Peter basolo
    Nov 24, 2014
    38
    How is this a problem?
  10. ian field
    Oct 27, 2012
    4,460
    792
    The battery will only last a few minutes.
  11. Peter basolo
    Nov 24, 2014
    38
    They have that Low of capacity? Or just burn out.
