Laser detector, frequency detector
Discussion in 'The Projects Forum' started by CaptainPrice, Jul 24, 2011.
  1. CaptainPrice
    Thread Starter Active Member
    Aug 12, 2009
    49
    What I want:
    a laser beam pulsing at some frequency by a 555 to be detected with a photo-resistor detecting that frequency set by the 555.
    The majority of the time the laser will not hit the sensor
    What can I use as a frequency detector? can a 555 be used
    What can I use to diffuse the laser beam to get a bigger sensor area?
    or Is there a better way to make a laser beam sensor [bigger sensor better detecting]?
  2. DickCappels
    Aug 21, 2008
    2,780
    675
    You can use the 555 and a gate to make a missing pulse detector, but you would probably be better off if you used something like an NE567 tone decoder.
    The is probably no reason to make the beam bigger -the amount of power will remain the same no matter what you do to the beam cross section (ignoring for the moment that the optics will have losses), unless you are concerned about damaging the photo detector.
    By the way, many aspects of your project are addressed at the URL below.
    http://circuitschematic.blogspot.com/2011/06/ne-555-lm-567-remote-control-circuit.html
  3. CaptainPrice
    Aug 12, 2009
    49
    Thanks Dick Cappels for the reply
    The tone detector was the IC I was trying to remember. I will have to research them more.
    The sensor area I need is about the size of a computer sceen.
    The beam laser beam will come from a 1mw laser.
    I'm trying to figure out also How to have an area the size of a computer screen sense the laser beam with the least amount of photo cells as possible. By diffusing or fiber optics etc. whatever is cheapest
  4. #12
    Nov 30, 2010
    16,705
    7,358
    Two ideas..I remember photo resistors as being rather slow, and Fresnel lens.
  5. CaptainPrice
    Aug 12, 2009
    49
    whats the max frequency photo resistors would work? -compared to photo transistor
    the only photo transistors I have are 900nm would red laser light work?
  6. Adjuster
    Dec 26, 2010
    2,147
    300
    What are you trying to detect - obstruction of the beam by an object or reflection from it? How big is the thing you are trying to detect?
    If you expand the beam, then a small object would only obstruct part of the beam, You might need multiple detectors to cope with that. Similarly, a small object can only reflect a small amount of power from an expanded beam, in which case high sensitivity will be necessary.
  7. CaptainPrice
    Aug 12, 2009
    49
    I want to detect when the beam hits the sensor.
    I want to shoot a laser beam at a sensor. regular weak laser beam. Most of the time the laser will not hit the sensor. When it does I want an output.
    On top of that I would like the sensor area pretty big (1ft x 1ft or bigger). So maybe if I wire up a bunch of photo resistors or transistors together the sensor will be bigger and maybe diffuse the light from an area between a photocell to the photosensor.
    I suppose I could expand the beam however I need it to work at different distance(1-20 meters) so I was thinking a regular laser beam would not disperse over that distance.
    but then again the sensor it hits 1x1 needs to be sensitive enough to give an output no matter where the beam hits on the sensor
