Laser dalek
Discussion in 'The Projects Forum' started by Lee HAWKES, Aug 22, 2014.
Thread Status:
Not open for further replies.
  1. Lee HAWKES
    Aug 22, 2014
    Hi everyone, I'm new here and rubbish at electronics so I need a little help, I have an r/c dalek which lights a blue LED on the end of its gun when it says exterminate, I successfully replaced the blue LED with a low powered laser (5mw), the laser is powered by its own battery's (two 1.5v AA), the power from the dalek now passes through a resistor (390ohm) and on to a transistor (bc 548) which in turn connects the laser to the battery's, but if I use a more powerfull laser (200mw) the dalek will not turn it on, I think because of the increased power that maybe the transistor needs to be changed but I'm not sure and I haven't a clue as to which transistor to use, the more powerfull laser operates off the same battery's as the weak one, can anyone help?
  2. shteii01
    Feb 19, 2010
    3,500
    511
    Need info on the laser. So far you only told us that it is 200 mW.
  3. joeyd999
    Jun 6, 2011
    2,756
    2,916
    So, you have a toy onto which you wish to install an actual weapon that can produce real damage -- like to a curious child's retinas?
    This will not end well...
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
Thread Status:
