I live in Toronto, Canada. I need at least 1/32 to 1/16 inch thick steel cuts.It would help if you told us whee you are located. It helps if the Laser company is local if you have never done Laser cutting before...
My first Laser-cut parts were done by a company that also does trophies. A local company that sell plastic sheet also has a Laser cutter.
The companies that cut plastic for me charged by the hour. There was no minimum quantity . You may be able to find a local company that charges the same way for metal. I would call a few metal fabrication shops and ask. Any good shop will give you a referral if it is a service that the do not do.See I have searched this and have found companies but I was hoping I could get a referral since I need low quantity pieces and the majority of them will probably ask for high volume.
Found the company called LaserNNet, they explained there was not minimum quantity needed. Will see how it goes from here.The companies that cut plastic for me charged by the hour. There was no minimum quantity . You may be able to find a local company that charges the same way for metal. I would call a few metal fabrication shops and ask. Any good shop will give you a referral if it is a service that the do not do.
by Aaron Carman
by Aaron Carman
by Aaron Carman
