Laser Alarm System Help
Discussion in 'The Projects Forum' started by tdab, May 29, 2014.
  1. tdab
    May 29, 2014
    I'm looking to make a laser tripwire to entertain my kids. I'd rather not spend a lot of money, and this video claims it can be done for <20 which is great. The only problem is I don't have a specific parts list to make it and I'm not familiar enough with these parts to know just by looking at them. Can you guys give me a list of (specifically) what parts he used in this video/what parts will work for them?
    Thank you all!
    link to the video: https://www.youtube.com/watch?v=t0FTzUhdg3w
  2. tdab
    May 29, 2014
    Also, what type of soldering iron should I buy?
  3. Matt D.
    Member
    Nov 10, 2013
    65
    He shows the schematic in the video with the components and how to hook it up.
    I think you can buy these parts from Radio Shack.
    102dB piezo siren
    NPN Transistor 2N3904
    1000uf Electrolytic Capacitor - this is polarized
    9V battery
    LDS Photocell resistor
    5K ohm variable resistor aka potentiometer
    perfboard to mount components
    2 project boxes
    Single pole single throw (SPST) switch
    cheapest soldering iron that runs on household current
    Solder
    Flux
    All this can probably be online for less.
    And from mfgcn.com
    AixiZ Power Adapter 3.2VDC Output;
    [A-PS-32-500m]
    635nm 5mW Laser Module 12x30mm
    [AH635-5-3-12]
    This is pretty cool, but doesn't really give enough information for people who have never made any electronic projects.
    I think you would be lucky to do it for less than $40. Just the laser module and power supply from mfgcn.com is going to run over $20 after shipping.
    If you want to try it and have any problems post back here and get the help to fix it. I'm not an expert but I think this is easy for the folks on here.
    Also, does anyone know if a laser pointer can be hacked to run continuously for this?
    And can't an old 5v power supply for a cell phone be used with a resistor for this instead of buying one?
  4. Matt D.
    Member
    Nov 10, 2013
    65
  5. Bernard
    Aug 7, 2008
    4,236
    414
    Post #1 schematic makes no sense, prob. same as post #4, same cost.
    Found a laser module on Electronic Goldmine, G 19D31 , or maybe D is 0 ?, @ US $ 2.29, same with battery, G196D1 . Also a laser target kit which seems to have all of your receiver parts except for siren , C 6739 @ $7.50. I think they have a $ 10. minimum.
    It is G19031, G19601 @ $ 1.99, also wall wart [ AC adapter ] G19115 6V, 500 mA, @ $ 2.99, add 100 ohm in series.
  6. tdab
    May 29, 2014
    That one does look much more simple. Will any size breadboard work with it?
  7. tdab
    May 29, 2014
    I would definitely buy EG's kit you posted, but I have no clue how to make it power a siren instead of light up LED's.
  8. Bernard
    Aug 7, 2008
    4,236
    414
    After looking at the kit ckt. board, does not seem to have mugh of what you want [ 8 LEDs in parallel driven by 2 PNP's ? in parallel, at least that is what it looks like to me ]
    Electronic Siren G19519 $ 5.00, or Tone Alert 12V, G17111, $ 1.79, or Audio Indicator G19721 $1.59
    All other parts are probably here also.
  9. Bernard
    Aug 7, 2008
    4,236
    414
    Look a post on Chat, Help choosing a transistor, post # 2 by inwo, use sounder in place of relay
  10. Matt D.
    Member
    Nov 10, 2013
    65
    Yes and the smallest should work.
