Large pin board supplier?
Discussion in 'The Projects Forum' started by bowlingo, Aug 20, 2011.
  1. bowlingo
    Jun 29, 2011
    162
    Hi all,
    I am looking for 2 x 300mm X 250mm pinboards (dot matrix board) for mounting loads of relays..ive had a look around but cant find anay big enough..I want to be able to put one pinboard on top of another with a series of relays below and above (I have plenty of depth in big adaptable box)
    I need the type where each hole is seperate rather than the ones with copper strips on..not sure of the name
    Ive looked on Maplin and RS but nothing big enough..
    I am in the UK
  2. KJ6EAD
    Apr 30, 2011
    1,426
    363
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    We don't know where you are, so it's difficult to suggest suppliers.
    In the States, Farnell is called Newark.
  4. bowlingo
    Jun 29, 2011
    162
  5. bowlingo
    Jun 29, 2011
    162
    hi all,
    I have found these ones..
    http://www.esr.co.uk/electronics/products/frame_pcb.htm
    The normal single sided copper clad boards go up to 12" x 8" (304mm x 203mm)
    Im after 12" x 12" (304mm x 304mm can cut it down if need be)
    Down the page they have 12" x 12" of which are 12 x 12"
    Single Sided Paper Photoresist PCB laminate
    There are no pin hole sizes though..
    Can anyone explain to me what the Paper Photoresist PCB laminates are please
  6. bowlingo
    Jun 29, 2011
    162
    Anyone any ideas on this...desperate to revamp a project...not enough space in adaptable box but lots of depth so planning on putting 2 x 300mm x 300mm pad per hole boards on top of each other and packing with relays...
    Had a look all over the place but cant find one 300mm x 300mm (12" x 12")
