laptop battery
Discussion in 'General Electronics Chat' started by Shimy, Dec 8, 2009.
  1. Shimy
    Dec 8, 2009
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Gee, too bad you used custom fonts. I can't even read your post, so I have no clue what you are talking about. The print is way too small.
  3. S_lannan
    Jun 20, 2007
    247
    The more expensive unit has twice the capacity. It will last longer between charges!
  4. maxpower097
    Feb 20, 2009
    795
    388
    As said above capacity. 4400mah vs 8000mah, in the most simple terms the voltage would equal the diameter of your glass and mah would = how deep your glass is. I know the EE's in the house are going to say this is wrong and go into and overly complicated explaination of Voltage, capacity, etc... But for buying a laptop battery the above analogy works.
