laplace
Discussion in 'Homework Help' started by hamza324, Sep 28, 2011.
  1. hamza324
    Jul 10, 2011
    33
    i just want to verify the answer i am getting is correct or not.
    -y'' + 3y' = 3x + 5x''
    now
    h(t) = - 18 e^(-3t) - 5
    using some other method i got
    h(t) = - 16 e^(-3t) - 3
    can some bdy help me out plzz.
    thnx
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Using Laplace
    -y^{''}+3y^'=3x+5x^{''}
    Transforming
    -s^2Y(s)+3sY(s)=3X(s)+5s^2X(s)
    \frac{Y(s)}{X(s)}=\frac{5s^2+3}{-s^2+3s}
    \frac{Y(s)}{X(s)}=\frac{-5s^2-3}{s(s-3)}
    \frac{Y(s)}{X(s)}=\frac{-5s}{s-3}-\frac{3}{s(s-3)}
    Inverse Transform for impulse response h(t)
    h(t)=-5(\delta(t)+3e^{3t})+(1-e^{3t})
    h(t)=-5\delta(t)+1-16e^{3t}
    which is an unusual result in that the function increases unbounded with time. Are you sure of the original equation?
    Clearly you now have three different results.
  3. hamza324
    Jul 10, 2011
    33
    Hi i got your answer.....
    but my professor told me slightly different procedure....
    i am getting the answer above except the impulse function in the asnwer..
    i.e h(t) = - 16 e^(3t) + 1 but missing that impulse thing..
    i have attached the file...plz give it a look
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    Yes - blink and you'll miss it.:rolleyes:
    One would have to ensure that the boundary conditions are met. At t=0 your answer is h(0)=0. What will you see in practice? I suspect an impulse output y(t) at t=0 is likely, due to the presence of the second derivative of the input x(t).
  5. hamza324
    Jul 10, 2011
    33
    i did the changed at h(0) at t=0 but answer isn't matching..
    but i understand your point so i think i would have to add this impulse at the end once i get the h(t) = - 16 e^(3t) + 1 expression.....am i right..
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    By definition, the delta impulse function only exists at t=0. Elsewhere it is zero so the function reduces to
    This is still an increasing value function with time given the positive exponential index.
    hamza324 likes this.
  7. hamza324
    Jul 10, 2011
    33
    thanks a lot for your help...
