Laplace transformation
Discussion in 'Math' started by boks, Dec 11, 2008.
  1. boks
    Thread Starter Active Member
    Oct 10, 2008
    218
    How can I transform
    F(s) = \frac{1}{(s-2)^2}
    I cannot see that any of the functions in my table is useful...
  2. steveb
    Jul 3, 2008
    2,433
    469
    You can use the partial fraction expansion
  3. silvrstring
    Mar 27, 2008
    159
    if L{e^(at)} = 1/(s-a) and L{t} = 1/ s^2
    then inverse L{ 1/(s-2)^2 } = f(t) = te^(at)
    There's a rule for it (a better way to put it). I have to go, though. If nobody posts it, put it up later.
  4. steveb
    Jul 3, 2008
    2,433
    469
    Oops, I see your problem. You already thought of the partial fraction expansion, but that doesn't work for the degeneracy.
    The above from silvrstring is correct: you can put the following in your table. It's needed for degeneracy cases with partial fraction expansions.
     {{1}\over{(s+\alpha)^n}} transforms to  {{t^{n-1}\over{(n-1)!}} e^{-\alpha t}\; u(t)
    with region of convergence Re{s} >  - \alpha
     {{1}\over{(s+\alpha)^n}} transforms to  -{{t^{n-1}\over{(n-1)!}} e^{-\alpha t}\; u(-t)
    with region of convergence Re{s} <  - \alpha
  5. boks
    Oct 10, 2008
    218
    I solved it, thanks.
