Laplace transform
Discussion in 'Homework Help' started by ihaveaquestion, Oct 12, 2009.
  1. ihaveaquestion
    Thread Starter Active Member
    May 1, 2009
    314
  2. steveb
    Jul 3, 2008
    2,433
    469
    It looks like you are trying to find the Laplace transform of a function g(t) equal to another function f(t) divided by time: i.e. L{g(t)}=L{f(t)/t}.
    Since you know the Laplace transform of f(t), you are using the known integration property; which is, division by time, in the time domain, corresponds to integration over s, in the s-domain.
    The only thing is that the final answer does not look right to me. Did you mean: arctan(s/B) instead of arctan(B/s)? I only looked very quickly, so perhaps I'm wrong.
  3. notxjack
    Sep 7, 2009
    20
    Are you asking us how to integrate that last term?
    How familiar are you with complex analysis?
  4. ihaveaquestion
    May 1, 2009
    314
    steveb, I'm pretty sure that's the answer (I found it in another laplace table online also).
    notxjack, no I'm not familiar with complex analysis... only how to do normal complex number algebra stuff.
  5. steveb
    Jul 3, 2008
    2,433
    469
    Ah ok, I think I see why it is correct. So which part is not making sense to you? Is the method you showed your own work and are you just trying to get to the final answer?
    Using an integration table for the last step, I get the following.
    pi/2-arctan(s/B)
    however there is a trig identity which shows this to be equal to
    arctan(B/s)
    Is this the confusion you are having? If not, please explain what the issue is.
  6. ihaveaquestion
    May 1, 2009
    314
    Yes, I just had no idea how to integrate that last term I wrote manually... not sure if that's common knowledge though.
  7. gregcoll
    Oct 11, 2009
    21
    See if you can follow this, it seems more difficult than it is:
    1. take a B from the denominator and you will have 1/B*int[1/(1+(S/B)^2)*dS]
    2. make the substitution-> S/B = tan (x), then dS = B*sec^2(x)*dx
    3. using the identity -> 1+tan^2 = sec^2, you should get simply 1*int[1*dx] (don't worry about the limits for now, always change back to your original variables when doing this to avoid missing any stray solutions!)
    4. the answer to this integral is simply -> x
    5. now, since S/B = tan (x) -> x = arctan(S/B)
    6. THIS is evaluated at the original limits of s to positive infinity which gives the previously given solution of pi/2 - arctan(S/B)m\, or -> arctan(B/S)
    NOTE: (arctan(infinity) must mean that the denominator of the tangent function has a value of zero and since tangent is sin/cos, the arc with cos=0 is at pi/2 and -pi/2 ergo arctan(infinity) is at the arclength of pi/2)
    7. use the fact that if a = arctan(x) then x = tan(a) and sin(-x) = -sin(x) and cos(-x) = cos(x) (and maybe some other identities) if you want to show the proof of the solution
    8. end
  8. gregcoll
    Oct 11, 2009
    21
    sorry, after looking over the steps I meant to say: take out a B^2 from the denominator. (and I don't know what that 'm\' is in step six
  9. t_n_k
    Mar 6, 2009
    5,448
    783
    This is how I did it ...
  10. t_n_k
    Mar 6, 2009
    5,448
    783
    Hi gregcoll,
    In case you were wondering what's going on with this thread, ihaveaquestion was asking for the Laplace Transform of the function, f(t)=sin(Bt)/t. The method for setting up the LT shown in the original working by the OP was incorrect and the integration shown there was not a requirement for a correct solution.
    Rgds,
    t_n_k
  11. steveb
    Jul 3, 2008
    2,433
    469
    t_n_k,
    Why do you say that the method for setting up the LT was incorrect? Are you sure about that? His method does lead to the correct answer, as I mentioned above.
    I do agree that the integration shown is not a requirement, but it seems to be a valid approach.
  12. t_n_k
    Mar 6, 2009
    5,448
    783
    Yes - you are absolutely correct. One of my not-uncommon brain "farts" I'm afraid.
    Apologies to all - "ihaveaquestion" especially.
    Rgds,
    t_n_k
  13. notxjack
    Sep 7, 2009
    20
    It's a complex integral over a line. It's a relatively straightforward process, though the steps will make no sense if you are unfamiliar with complex integration.
  14. gregcoll
    Oct 11, 2009
    21
    You are exactly correct, a complex integration using the residue method is more thorough but unnecessary in this case as you know it will lead to the same result. I did not include these methods as it seemed that ihaveaquestion might not be familiar and it is better (I think) to not scare people, especially scientists and engineers, from math and this method might seem more familiar. Sorry for any ambiguity.
