Laplace transform method (using matrices)
Discussion in 'Homework Help' started by u-will-neva-no, Nov 6, 2011.
  1. u-will-neva-no
    Mar 22, 2011
    230
    Hi :)
    This is the question I am facing. I will then show my solution up to the point that I am stuck on:
    Question: Consider the matrix
    A=\left{ \begin{array}{lml}<br />
0 & \, & 1\\<br />
1 & \, & 2\\<br />
<br />
\end{array} \right\} <br />
    Determine exp(At), by using the Laplace transform method.
    Current solution:
    I used the formula
     SI - A so:
    s\left{\begin{array}{lml}<br />
1 &\, & 0\\<br />
0 &\, & 1\\<br />
\end{array}\right\} - \left{\begin{array}{lml}<br />
0 &\, & 1\\<br />
-1 &\, & -2\\<br />
\end{array}\right\}<br />
    This comes to:
    SI -A = \left{\begin{array}{lml}<br />
s &\, & -1\\<br />
1 &\, & s+2\\<br />
    Finding the inverse gives:
    (SI -A)^-^1 =\frac{1}{s(s+2)-(-1*1)} \left{\begin{array}{lml}<br />
s+2 &\, & 1\\<br />
-1 &\, & s\\<br />
    This simplifies to:
    (SI -A)^-^1 =\frac{1}{(s+1)^2} \left{\begin{array}{lml}<br />
s+2 &\, & 1\\<br />
-1 &\, & s\\<br />
    or:
    (SI -A)^-^1 =\left{\begin{array}{lml}<br />
\frac{s+2}{(s+1)^2} &\, & \frac{1}{(s+1)^2}\\<br />
\frac{-1}{(s+1)^2} &\, & \frac{s}{(s+1)^2}\\<br />
    I am not sure what to do next. I know that I need to take the Laplace of the final expression but I don't know how to do that... Any help, other examples would help alot!!
  2. Peytonator
    Jun 30, 2008
    105
    You're wanting the transition matrix e^At, right? You need to first split those factors inside your final matrix into partial fractions, then take the inverse laplace transform of the whole matrix (i.e. use the laplace transform tables to find the inverse transform of each term)...
    u-will-neva-no likes this.
  3. u-will-neva-no
    Mar 22, 2011
    230
    Thanks Peytonator, that helped me out! :)
