Language
Discussion in 'The Projects Forum' started by parkerp1000, Sep 13, 2012.
  1. parkerp1000
    Sep 13, 2012
    I am doing a project on IC's and I can't find what language most IC's are programed in please help.
    thanks,
    Parker
  2. #12
    Nov 30, 2010
    16,658
    7,304
    Most IC's aren't programmed.
  3. Papabravo
    Feb 24, 2006
    10,338
    1,850
    "Solder is my favorite programming language"
    -- Steve Ciarcia
    DerStrom8, absf and Sparky49 like this.
  4. Sparky49
    Jul 16, 2011
    835
    417
    That's a good quote.
    @Parkerp, there isn't really one language which stands out for programming microcontrollers, however, I would hazard a guess at C (or varients of) would be the most used.
  5. Papabravo
    Feb 24, 2006
    10,338
    1,850
    There were a lot of PALs that were programmed in Abel and CuPL not to mention PALASM. Altera and Xilinx both had proprietary languages and VHDL and Verilog are used for large scale projects.
  6. Dodgydave
    Jun 22, 2012
    5,134
    767
    Which IC's are you looking at in particular?
  7. MrChips
    Oct 2, 2009
    12,623
    3,451
    All programmable digital devices are programmed in binary.
    djsfantasi and Sparky49 like this.
  8. toffee_pie
    Oct 31, 2009
    162
    7
    for mainstream vlsi devices and the such verilog/vhdl would be the main ones, for lesser microcontrollers c,assembly.
    i think if you were fluent in c, assembly and a hdl you would be pretty safe. :p
  9. Sparky49
    Jul 16, 2011
    835
    417
    Guru Chips is spot on. :D
