lamp switch panel?
Discussion in 'General Electronics Chat' started by relicmarks, Nov 1, 2008.
  1. relicmarks
    Thread Starter Active Member
    Oct 13, 2006
    355
    when testing 10 digital inputs , my test fixture uses 10 on/off switches to +5volts
    when testing 10 digital outputs, my test fixture uses 10 lamps
    who makes a box/unit that has a bunch of LEDs or lamps that are in parallel that have switches to turn off each Lamp or LED ?
    10 lamps in parallel with 10 switches in parallel to turn them off or on, who makes a box/unit like this please?
    The lamps on my homemade text fixture give my eyes black spots and head aches , do u know what i can use over them like a filter or lamp shade? they are just small bulbs
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Reduce the voltage/current, make a filter.
    It sounds like making such an indicator box would be cheaper than buying one.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Nobody that I know of. However, you can get 10-position DIP switches and 10 LED dot/bar displays pretty inexpensively. A SIP (single inline pin) resistor with 10 internal commonly-connected resistors would make it easy to connect up, using a perfboard.
    You need a diffusion lens. A translucent piece of plastic like a piece of a milk jug should work pretty well. A finely woven piece of white cloth (like an old bedsheet) or piece of typing paper would also work. Put it a half-inch or so away from the lamps, between your line of vision. Super-bright LEDs can cause permanent eye damage; don't look at them.
  4. relicmarks
    Oct 13, 2006
    355
    ya i tried the dip-switches but my fingers hurt after using them so much during testing
    Because when testing digital chips that have multiple inputs and outputs i use switches to +5 for the inputs and Lamps/LEDS for the outputs
    So i'm trying to find a box/unit that has a bunch of switches for the inputs and another box/unit with just LAMPs or LED's for the outputs
    another example is if you have a motherboard of a circuit (not a computer motherboard) that has 15 molex connectors for the inputs and 15 molex connectors for the outputs
    I need to test every input and output of each molex connector which has 8 wires to each molex connector , so thats alot of input wires and output wires
    using switches tied to +5 volts to each wire on the molex connector so i can toggle the inputs and than have a LAMP on the output molex connector wire
    using Switches to +5 volts on the inputs and LAMPS on the outputs help than using a logic scope to test digital signal tracing
    I need a switching matrix or panel thats in a chassis frame with Lamps or LEDs
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Rebuild the tester. Use toggle switches instead of DIP switches. Use diffused LED's instead of bright lamps.
    I rebuilt a couple of testers at places I worked.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    This sounds like a build-it-yourself project.
    If you're going to use LEDs, I suggest getting either widely diffused types, or those with a milky lens.
    Most of the cheap Chinese LEDs for sale on auction sites nowadays are super-bright, and have a very narrow focus angle with "water clear" lenses. In my opinion, those are not suitable for your purpose; you'll get those "black spots", headaches, and there is a very real possibility that you will permanently damage your vision.
  7. relicmarks
    Oct 13, 2006
    355
    ok thanks alot guys
    i thought i was going to do vision damage
