Why? You would need to have a separate constant current source for each string of LEDs. Use a constant voltage source with multiple strings of LEDs with a current limiting resistor in each string. Pick the number of LEDs so that they drop about 3/4 of the voltage and drop the rest across the resistor. Put the same kinds of LEDs in each string so that their brightness will be reasonably close.Hunter;625047 said:Forget about resistors use a constant current source for the love of Christ.
I'm totally confused.Basically there is on strings:
124 - 14.6341463 ohms
118 - 15 ohms
39 - 46.1538462 ohms
1 - 600 ohms
All in blue
88 - 20 ohms
88 - 20 ohms
50 - 35.2941176 ohms
All in white
33 - 85.7142857 ohms
In red
Each one of these strings are connected in parallel to a central wire. Being as they all differ, are you saying add each of these values up to calculate the current draw when you say 'add them up in groups' ?? Once again many thanks for your help
I can't figure out how what you say above correlates in any way with what you say below:Basically there is on strings:
118 - 15 ohms
1 - 600 ohms
All in blue
88 - 20 ohms
88 - 20 ohms
All in white
In red
In the first post, for the red, you saidMy apologies:
Right ill start from the beginning - the driver gives the following output:
12V
5A
The red circuit is arranged as:
5 LED's connected in series which are attached to a 100 ohm resistor if I remember correctly (all series circuits regardless are resisted appropriately). this is then connected o parallel with the other 28 in the same configuration. the three remaining are also in series attached to a 330ohm resistor so this accounts for all of the reds.
Then the whites and blues are connected 3 and a resistor in series.
So the first number corresponds to the number in any given series/parallel array.
Each of these circuits is then attached in parallel to a central wire leading to the driver (I.e separate from the other circuits)
The values I've calculated are based on R = V/I with the voltage being 12V and the current is given by an online calculator
Those can't be trusted.Oh btw I've calculated this using ohms law from a current value given off an online calculator
You are making extra work for yourself.Just off the top of my head for example - I THINK it said 88 white in series/parallel draws 600mA so using ohms law 12 / 0.6 is 20 ohms.
... My original calculation of net resistance was formulated by getting values of resistance for each series/parallel circuit and then running it as follows:
Lets say:
Resistance of 124 LED's is 'a'
Resistance of 78 LED's is 'b'
Resistance of 129 LED's is 'c'
Total resistance=
1/(1/a + 1/b + 1/c ... Etc)
by Jake Hertz
by Duane Benson
by Don Wilcher
by Robert Keim
