Hi _mech. Yeah the LED's are 5mm and will be through hole as opposed to surface mount. I've not bought anything yet apart from a few of the LED's so so far as the power source is concerned I'm not limited to anything. Ideally it would be a higher voltage supply than the 12V drivers that I've Been recommended to get. I'm guessing LED drivers are the only way to go as they convert to DC supply and regulate the current? I'm guessing 12V is also the best choice as any more and it would have serious implications for heat management and possibly melting wire??I'd still like to "see" your intended layout or a picture of image you're making. This would give us a better idea of what kind of spacing you're looking at. Still need to know what LEDs you're thinking of: 3 or 5mm through-hole, surface mount, etc,? I'll ask one more time:
Is the following correct?
Now some questions:
- You are limited or simply choosing to use a power supply rated at 12VDC at 4A, roughly 45W?
- All the LEDs are going to be mounted to a board that is 54" x 54"?
- Have you already selected or decided which LEDs you're going to use? If yes, please post links to these.
- Will the LEDs be thru-hole such as 3mm or 5mm or SMD? There's also high power LEDs, but I don't think you'd be able to get that many on such a small area.
- Is this display going to be viewed indoors or outdoors? If outdoors, will it be viewed in sunlight, at night, or both?
- What is the closest distance someone will be viewing the display?
- What is the farthest distance someone will be viewing the display?
- Can you post a rough drawing or picture of the overall image you're trying to create with the LEDs? You don't need to draw hundreds of dots, just a line or shape will do.
- Are you simply wanting to have the LEDs on or do you want to be able to make some or all blink and/or fade?
- I'm curious how you got the current and wattage requirements for the LEDs. If I'm following correctly, it appears you've planned to connect three LEDs in series and parallel these sets. If so, then the red LEDs are getting 10mA each and the blue and white LEDs are getting 20mA each. Is this correct?
- What material is the board going to be made from? 1/8" plastic, 1/4" plywood, etc.?
- Will there be a cover over the display, e.g., glass, plastic, etc.?
Hiya buddy - if you look at the images I have enclosed and seen how the project is constructed, its not possible unfortunately. Yeah that's not such a bad idea reducing the LED's. 1ohm of resistance Is important not to overlook that though? I asked earlier on if it's such that the only reason they include the value of 1 is so the equations don't equate to 0. If I didn't put a 1 ohm resistor in there would be trouhble??Some of your strings show a 1 ohm resistor. You need to use one less LED in that string and increse the value of the resistor. I still maintain you can use 12V strips of LED's to accomplish what you want. It will save you work on mounting LED's, wiring them and such. If you want all the LED's to have the same intensity , or for the matter if you want them to have different intensities,reguardless of the wiring you can use PWM with each color. All LED's donot require 20 milliamps of forward current to produce the same intensity.
WBahn thank you for your inputs:Getting a better schematic together along with some specs on the LEDs will help a lot. Other points to consider clarifying:
1) Explain where your power/current numbers came from. It's not at all obvious and strangers that are asked for help are far more likely to help if you don't make them guess or reverse engineer your thoughts using a crystal ball.
To try to answer some of your questions:
If you use a 12V voltage source with a 4A rating, then it can supply UP TO 4A while holding the voltage at 12V (which would be 48W, not 45W, but that's in the ballpark). Each circuit that is connected across the supply will draw whatever current it will draw at 12V. As long as the sum of all such currents does not exceed 4A, then each circuit is independent and won't even know the other circuits are there (i.e., connecting/disconnecting one should have no significant impact on the others).
I'm not picturing what you have in mind. 52x3=156, so what is up with the 157th LED?
As long as you use sufficiently large wire to connect the brnaches to the string, the voltage drop along the string can be as small as you want. How long, physically, will the longest string be?
And I addressed this point.I asked earlier on if it's such that the only reason they include the value of 1 is so the equations don't equate to 0. If I didn't put a 1 ohm resistor in there would be trouhble??
If you would take the time to crank the numbers on a few of the scenarios I spelled out, you will see that using a 1Ω resistor is completely unsatisfactory. The smaller the resistor, the less unstable the current.What is the current, I, in the string with 6 LEDs?
I = (Vs - 6Vd)/R
Now, plug in the following values:
A) Vs = 12V, Vd=2V, R=1Ω
B) Vs = 12.5V, Vd=1.8V, R=1Ω
C) Vs = 12V, Vd=1.8V, R=1Ω
D) Vs = 12V, Vd=2.2V, R=1Ω
E) Vs = 12V, Vd=2V, R=1.1Ω
F) Vs = 12.5V, Vd=1.8V, R=0.9Ω
G) Vs = 12V, Vd=1.8V, R=1.1Ω
H) Vs = 12V, Vd=2.2V, R=0.9Ω
If you don't need to flash, dim, etc. the LEDs, then all you need are resistors and a DC power supply. This can be what we often call a wall wart, although you may need something a little bigger to provide enough current. It isn't a driver so much as power supply that converts your AC wall power to DC power.I'm guessing LED drivers are the only way to go as they convert to DC supply and regulate the current?
Not quite - unless you select a tiny wire or put all of this into small box with zero air flow, I don't think overheating is going to be a concern with this project.It's worthy to note that once switched on they probably won't be on for much more than an hour or two at the most but I guess in terms of heat and stress on the component they will get to optimum use within a few minutes??
This may affect the LEDs appearance (light output, not so much physical appearance). If you opt to use a varnish, I suggest you apply it before installing the LEDs so they stay varnish free.No there is no cover to go over the top of it although I am considering spraying it with a shiny varnish to finish it.
Ah sorry for missing that one dude. Point taken so I basically need to reduce the LED's till I can find a resistor which will balance the current to a satisfactory levelAnd I addressed this point.
Case D won't result in any current at all, regardless of what size the resistor is.
Case F will result in nearly two amps of current instead of 20 milliamps - or 100 times what you want.
Ahh cool maybe I will consider that then I take it there's no issues with current regulation then and power surges etc? They will go across the window and then slide open ... I'm planning on a device which will automatically open it at 11am each dayIf you don't need to flash, dim, etc. the LEDs, then all you need are resistors and a DC power supply. This can be what we often call a wall wart, although you may need something a little bigger to provide enough current. It isn't a driver so much as power supply that converts your AC wall power to DC power.
I was a little confused by your explanation. So is this being hung on a wall like a picture frame or being used as shutters?
Okay, 5mm LEDs it is. With a half (inch?) of wood plus tile, the base will be robust but thick. This will make it a little challenging to mount the LEDs. Typically one drills a hole big enough to allow the LED dome through but small enough to allow the LED lip to catch or uses an LED holder. In both cases, this only works for material about 1/8 inch thick. In your case, you'll need larger holes to allow the whole LED to pass through then seal it somehow, perhaps with caulk. Another concern is being sure the LED is oriented straight (perpendicular to the surface) as the caulk sets or however you decide to fasten them.
The white and blue LEDs you've selected will be extremely bright - like looking into a flashlight bright. If this was for an outdoor application and viewed from tens of meters away or more, then they'd be fine. Since this is for an indoor application with a short viewing distance, I'd strongly suggest looking at diffused LEDs for the white and blue like the red ones you've selected. Something like this and this. Look for a rating of about 100mcd. Anything in the 1000s will be blinding.
Also note the blue and white LEDs will probably still be brighter than the red, so you may find you want to either increase the current to the red LEDs by selecting lower valued resistors or dim the blue and white by using higher valued resistors to increase or decrease the current, respectively.
Other members have already said it, but I'll say it again - six red LEDs in series will not work at 12VDC. The reason is the forward voltage to a red LED is ~2V. Six in series requires 12V minimum. In layman terms, you need at least another volt or two to spare to allow a resistor to properly limit the current going to the LED. WBahn has tried to point this out to you mathematically. You'll need to put five LEDs in series or use a power supply with a higher voltage than 12VDC. There should be no reason not to wire five in series as opposed to six - you can always run wire longer distances if needed to put the LEDs where you need to. I'll work on the power requirements when time allows to see if your proposed 12VDC, 4A supply will be able to provide enough power.
You can dim them some by reducing the current by increasing the resistor value. This will only go so far and the white and blue are still going to far outshine the red. You can diffuse them yourself by sanding the LED. It will still be bright, but perhaps not blindingly so. Give it a shot with a couple of spare LEDs first and see if you get the results you want. Be sure to test all three colors together so you can "see" how bright they are relative to one another.Ahhh shucks I've already brought the LED's :-( so am I right in saying that if I reduce the current they will dim?? Only I read somewhere if you reduce either current or voltage they simply won't work at all . Upon thinking about the science of it I'm guessing reduced voltage will prevent them from working yeah?
The 1 ohm would be useless as it will have little if any on limiting the current limit which is important for LED's. Another point, the intensity of LED's varies and to achieve the same amout of light with less LED's is accomplished with fewer LED's at a higher MCD.Hiya buddy - if you look at the images I have enclosed and seen how the project is constructed, its not possible unfortunately. Yeah that's not such a bad idea reducing the LED's. 1ohm of resistance Is important not to overlook that though? I asked earlier on if it's such that the only reason they include the value of 1 is so the equations don't equate to 0. If I didn't put a 1 ohm resistor in there would be trouhble??
by Aaron Carman
by Jeff Child
by Aaron Carman
by Jake Hertz
