is there one who can help to solve the problem in labview plz....
This assignment is designed to work on a set of sampled data taken from a strain gauge. The samples are stored in an appropriate array of up to 100 elements. A correct value should be greater than or equal to zero or less than or equal to 5 volts:
0 < value < 5 (V)
Specification 1 (80%)
To design a VI that will identify the position of and the number of any overshoot values (a value greater than 5) and the position of and number of any undershoot values (a value less than 0)
The front panel will consist of the following:
An array of controls holding the sampled values.
An array of indicators holding the index values of where each overshoot occurred
An array of indicators holding the index values of where each undershoot occurred
An indicator holding the total number of overshoot values.
An indicator holding the total number of undershoot values.
Hint: Research Build array and Initialise array functions.
Specification 2 (100%)
To design a VI that will attempt to meet specification 1. However if 5 successive values are overshoots or five successive values are undershoots then the data is corrupt. If this occurs analysis will be aborted and an error LED will be illuminated.
0 < value < 5 (V)
