Labview Tips
Discussion in 'Homework Help' started by neo1111, Nov 22, 2014.
  1. neo1111
    Jan 11, 2014
    28
    Hi there!
    I have an issue with a project of mine. I have to make an app using MEMS and DAQ-MX in order to turn 2 leds on depending on the position of the MEMS. Let's pressume i rotate the mems left and it switches a red led ; if the mems is being turned/flipped right side , then in should turn on a green led .
    The MEMS in LPR530- motion sensor: dual axis pitch and roll ±300°/s analog gyroscope.
    I would be grateful if someone could help me , even with some sort of example (/documentation ) .
    Cheers !
  2. neo1111
    Jan 11, 2014
    28
    I must say that i don't have the wpi robotics library so ...;(
