Labview, multiplexing Demultiplexing a signal
Discussion in 'Programmer's Corner' started by onqun, Jun 27, 2010.
  1. onqun
    Feb 17, 2009
    15
    Hello guys, I have project, I generated 3 waves and I have 2 wav files. I need to multiplex and demultiplex them. I looked online. point is I have no idea about multiplexing and Demultiplexing. Can someone explain me?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    If your question specifically relates to Labview then you will find a wealth of information at the National Instruments website.
    Go to http://www.ni.com/
    and check out "Developer Zone" in particular. You may have to create a user profile but it's worth the effort.
  3. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    Do you maybe want to move the values into and out of an array?
  4. t06afre
    May 11, 2009
    5,939
    1,222
    It is a Labview forum here http://forums.ni.com/t5/LabVIEW/bd-p/170 You have to click through a lot of pages to find it via http://www.ni.com/, if you find it. But feel free to post your code here also. I can take a look.
    onqun likes this.
  5. KL7AJ
    Nov 4, 2008
    2,047
    295
    Howdy:
    Were these files generated in Labview? If so, you can use one of the easy waveform manipulation functions from the waveform toolbox. If not, you can use the ARRAY functions to redistributed the data into individual arrays.
    Eric
    onqun likes this.
