Lab Suppy Help
Discussion in 'General Electronics Chat' started by oidium45, Nov 12, 2010.
  1. oidium45
    Thread Starter Active Member
    Apr 24, 2010
    130
    8
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I came up with these awhile back; both could be run off the same 20v-36v unregulated supply. Both are rated for 2.5A; could go to 5A by changing the regulators to LT1170's. Pretty simple. You can add meters if you wish.
    In the 2nd schematic, L3 is optional - but helps considerably with the power dissipation in R5. Without it, R5 will dissipate around 1W.
    oidium45 likes this.
  3. oidium45
    Apr 24, 2010
    130
    8
    Thanks sgtwookie
