If both logic inputs for one side of a L293D are connected to the same value, then both outputs are both connected to either +V or 0V. There is no short across the power supply in this case; there is zero current through the motor as both sides are forced to the same potential.Keep in mind that for H-bridges, you need to ensure that both sides of a bridge should not be turned on at the same time, as that creates a dead short across the power supply.
Another Indian Einstein.If both logic inputs for one side of a L293D are connected to the same value, then both outputs are both connected to either +V or 0V. There is no short across the power supply in this case; there is zero current through the motor as both sides are forced to the same potential.
This behaviour is illustrated in the data sheet on page 6 ( Fig 9, Bidirectional DC Motor Control) and may be used to stop a motor by inductive braking - in effect it shorts out the motor, not the power supply.
There would be a short if both transistors on one side of a bridge were turned on; generally if you change the direction of either side you disable the bridge during the transition, though an integrated bridge should have protection against this. Such shorts are nothing to do with whether you use an inverter between the two sides of a bridge.
by Aaron Carman
by Duane Benson
by Jake Hertz
by Robert Keim
