L298 parallel connection
Discussion in 'General Electronics Chat' started by catalinstefanos, Jun 5, 2011.
  1. catalinstefanos
    Jun 2, 2010
    Hello guys. I would like to connect two L298 in parallel to drive a stepper motor which needs 2.2 Amps.
    Is it good the schematic i posted? I want to use 1N5822 diodes. Should i also use some ceramic capacitors? Thanks. schema1.png
  2. shortbus
    Sep 30, 2009
    4,086
    1,665
    L298 chips are out dated chips for stepper driving. A dedicated stepper driver chip is a better option.
    A dedicated driver chip will have a built in PWM to control the current to the motor which is important. Stepper motors are very tolerable to voltage( should actually be ran at 10 - 20 times the name plate voltage of motor) But very intolerable to over current.
    A dedicated driver will also generate the step sequence for the motor including micro stepping. Micro stepping makes the motor operate much smoother.
  3. catalinstefanos
    Jun 2, 2010
    And a name for dedicated driver chip please? L298 is very easy to implement. Someone suggested L6208 but its very ambigous how to interface it with a microcontroller. I want a simple solution. Thanks
  4. bawan
    Jun 4, 2011
    :D;):rolleyes::cool::eek::confused:.................
  5. shortbus
    Sep 30, 2009
    4,086
    1,665
  6. shortbus
    Sep 30, 2009
    4,086
    1,665
    Good first post on the site. Why do this instead of helping?
