1. cpleng7
    Thread Starter Active Member
    Dec 18, 2008
    120
    is that the motor driver cannot have the common ground with the microcontroller?
  2. lihle
    Apr 12, 2009
    83
    try to be more explanatory so that we can see what your problem. i dont like guess work since now i have to guess.
    ok.The motor driver can use the same common ground but if you are using bread board try to check if your wires are connected firmly. as for the veroboard check that you have solder correctly then test. try to verify your connection. current i am using one h-bridge i have developed personally sharing the same GND with the micro controller.
  3. cpleng7
    Dec 18, 2008
    120
    actually now i am using the motor driver and the MCU in the PCB board that design by me
    i have try the simualtion in the proteus software the coding can work. but after i work out with the circuit in the PCB i found out the voltage that given out from the port will drop to 0.++ after a few turn of the dc motor.
    I not sure what is the problem on there. is that we can't use tamiya motor with the motor driver?
    or current too small produce by the motor driver?
  4. cpleng7
    Dec 18, 2008
    120
    some more the problem is the microcontroller will heat up when the switch is on.
    can some can help to solve the problem?
  5. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Post your schematic.
  6. cpleng7
    Dec 18, 2008
    120
  7. t06afre
    May 11, 2009
    5,939
    1,222
    According to your schematic you have not used a series resistor on the LEDs connected to the CPU. That is a NO-NO. Use around 300 Ohm. Or calculate the series resistor with data from the LED data sheet
  8. cpleng7
    Dec 18, 2008
    120
    yaya i have burn the all three led
    by the where is that my connection of the diode is correct? the diode is using correct?
