I built L297 & L298 stepper driver (All same as attached image PLUS a capacitor and var-resistor to limit current).
I attached simple LED to four wires that goes to stepper motor to CHECK the output of signals.
All four LEDs work fine, on, off, on, off....... means, it works fine. But L298 does not turn hot even a bit, I think it should turn hot some bit even without motor.
But When I attach stepper motor wires along with LEDs, then all LEDs keep ON, these all LEDs should work fine with stepper motor as before without motor. So the stepper does not move.
I also tried to adjust the var-resistor, but still it remain same.
Please guide me what may be the reason that the signal output is not good and what is the solution.
Note: I also have build another same stepper driver, it works all fine with and without motor.
